Results 1 to 7 of 7
Thread: Seat belt bolt size - upper B column
    Sep 2007
    Norway
    Hello guys!
    I have welded in upper seat belt fasteners in the B-column in my 67 like the LWB cars. Threaded plate from Lloyd. But which size is the threads? It is smaller than the usual threads and a bit bigger than standard 8mm bolt. Are the bolts higher strenght than normal bolts (8.8)?
    '67 911S Sunroof, Polo Red(Project disguised as a G-model)
    '67 912 Sunroof, Light Ivory(Alive and kickin')
    '67 912 SWTarga, Signal Red(Project in the making)
    X: 67 911 Coupe + 67S Targa, 912, 924, 944, 928, 356
    Apr 2004
    35,000 ft
    I believe all seat belt bolts in all cars are 7/16-20
    Aug 2011
    Eugene, OR
    Quote Originally Posted by blucille View Post
    Correct, as far as it goes. SAE 7/16-20 is also virtually interchangeable with M11x1.25, which may be easier to find in many parts of the world.
    - Arne
    Sep 2007
    Norway
    Thanks for your answer! Are you sure the B-post threads on LWB cars also are as large as 7/16? I have a 71 tub which have smaller hole, but will double check!
    Also, anyone know of a good type/supplyer of automatic 3-point belts which look ok and has a direct fit in a late SWB car (with added B-post point)?
    All bolts in Porsches are metric.
    Never imperial.
    Aug 2011
    Eugene, OR
    Quote Originally Posted by 91167coupe View Post
    My early '72 is 7/16-20.
    Quote Originally Posted by blue72s View Post
    Never imperial.
    Except early seat belt fasteners. US DOT mandated that size and thread. All cars that were ever intended to be sold in the US had 7/16-20.
    - Arne
    Quote Originally Posted by Arne View Post
    OK thanks.
    91167coupe,
    Go to a Porsche dealer. Part number for the bolt is 901.803.145.00
