Results 1 to 9 of 9
Thread: How to replicate finish...on alu calipers
    I have refinished my rear ATE calipers with yellow zinc, and they look great. My front calipers were long ago swapped out for Bremtek aluminum four piston calipers.
    They were originally dark anodized, and now they are back to raw aluminum color. I would like to make them resemble the "watery yellow" finish on the rear steel calipers. It was suggested that I "dust" them with a gold rattle-can color . I picked up a can of this at the auto parts store and have two problems with this suggestion...1) the gold is waaay off the yellow zinc color and 2) it is not high temp. Suggestions? And no I am not interested in sending them off to be refinished.
    I would like to solve this myself. Any metallurgists out there that have experience with coating aluminum?
    registry# 1283
    Jul 2011
    Chicago Area
    Interested in this also!.
    Mike Fitton # 2071
    2018 911S Carrera White
    Jul 2008
    South Florida
    Never tried their products on calipers, but VHT makes dependable hi-temp rattle can paints... found this first click: https://www.amazon.com/Dupli-Color-E.../dp/B000994BUW
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    May 2014
    South East USA
    Did you try this?
    If you polish metal, and dust this. It seems to work well.
    This guy from 'Mike's Restorations' Youtube channel has a great video on the zinc plating process for SWB Porsche calipers.
    https://www.youtube.com/watch?v=SBQDZI5xz4w
    He also has a second video where he rebuilds them with new seals
    https://www.youtube.com/watch?v=Wt3huX8llsE
    He uses the Caswell electroplating system and has gotten some really nice results.
    Yes, but Tonger, zinc plating doesn't work on aluminum. Aluminum requires anodize. That is why Speedo is trying to find a substitute that will work on aluminum. He needs an anodize that matches the color he is after. Or, he will have to settle for spray paint, which will look like spray paint. Perhaps Scott A.'s suggestion will provide a good enough result. It will be helpful to get a follow-up if Speedo tries this.
    Jul 2008
    South Florida
    Quote Originally Posted by Scott A View Post
    Did you try this?
    Sheesh. Did you notice the Amazon link below to that very product before posting? SMH...
    Russ
    ESR # 1537
    '70 914/6 GT
    Quote Originally Posted by Jim Morris View Post
    You are absolutely right, my bad. It looks like the aluminum chemical film process is something called yellow iridite. That is something you would need a plater to help with.
    https://www.smlease.com/entries/fini...rsion-coating/
    https://difco.us.com/chem-film/
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    I had mine done at a local anodising shop in the Netherlands.
    They were also able to do the neccesary prep work like grinding and polishing.
    Color was regular gold anodising, but they were able to tune the shade somehow to light gold.
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
