Results 1 to 10 of 13
Thread: Source for 14mm ATF blue lock nuts for early valve covers
    Does anybody know if these are available?
    TIA,
    JK
    There used to be a supplier in Ca. that had hardware and gaskets.They were very very good.I used them back in the 90's I can't remember their name though.If I do I'll post it.Can anybody else chime in?P.S not the normal importers.
    Looks like SSF has them.If you need some let me know.
    The place I was thinking about was Wrightwood Racing.Does anybody know if there still around?I did a google search but nothing came up.
    I just did a valve adjust on my 69s and the gasket kit came from wrightwood with blue nylon in the lock nuts. I bought them through my local independent
    Porsche repair shop.
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    I get them by the hundreds from Metric & Multistandard Corp.
    Just went and checked size. The nuts on my 69 are 13 mm, so if the earlier cars used 14mm then you probably need to check with wrightwood.
    1969 911S
    Oct 2010
    Southern Ca.
    Wow , no ones reading the important part , 14 mm ATF . SSF and MMCC do not sell these . I don't think there is a source , hopefully I'm wrong .
    Richy and I have discussed this many times, never found a source. I do have one old stock 14mm ATF nylock if measurements are needed.
    Joris, if you find anything on your side of the pond or make a batch I would love to buy some.
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Brad, I have been playing with the idea of having these made. I have done quite some hardware for the 356's over the years to ensure authenticity. Will probably PM you to confirm some measurements
