Results 1 to 2 of 2
Thread: Flasher relay 67 90161534110
    Senior Member softwindow's Avatar
    Jan 2015
    Bonn, Germany
    Are there suppliers of flasher relays (90161534110) for 67/68
    Kind regards
    Anke
    356 A 58 silver
    302485 light ivory
    500248 Softwindow light ivory
    500441 Softwindow S light ivory
    2.2 S Targa geminiblue
    2.4 T Targa black
    2.4 S Targa vipergreen
    2.7 RSR tribute green (original 2.4 E 1972)
    Macan GTS black
    Boxter S black
    997 Turbo Cabriolet black
    BMW R 17
    BMW R 69S black with Steib 500
    Nov 2008
    Finland
    No, not available. There are loads of info about this topic but if you search e.g. stribel can, you'll find way to make it. (thanks to 304065 , John Cramer) But it'll not look like original can.
    E.g. this: https://www.early911sregistry.org/fo...Analyzed/page2
    I had few of these, one started to work nicely after connected directly to battery BUT you'll need bulbs/bulb holders to test it as there needs to be resistance, preferably app. 25W per bulb. It won't work without bulbs as it needs to heat up to work. (I also spent way too much time trying to find an alternative )
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
