Thread: Oil Sump Drain Plug with internal 10mm hex
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    Hi Guys,
    Can anyone tell me the part# for the Drain Plug with 10mm internal hex fitted to early SWB 911s?
    Or even a source.
    Search is not finding much.
    TIA,
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    OEM External Hex, Magnetic:
    PET '65-'69 911 Fig. 1-01-05, #45 901.107.176.00 Magnetic screw, -68 Qty: 1
    PET '65-'69 911 Fig. 1-01-05, #45) 901.107.176.01 Magnetic screw, -69 Qty: 1
    PET '65-'69 911 Fig. 1-04-00, #51 901.107.176.00 Magnetic screw, -68 Qty: 1
    PET '65-'69 911 Fig. 1-04-00, #51) 901.107.176.01 Magnetic screw, 69- Qty: 1
    OEM Allen, Non-magnetic:
    PET '90-'94 964 Fig. 1-01-10, #19 900.219.009.30 Screw plug, M18x1.5 (no magnet) Qty: 1 Stoddard, $4.74
    Feb 2003
    Thanks Jimmy! No luck with part # 901.107.176.01 with the “usual suspects”.
    I did mange to find the later drain plugs, but they are M18. The standard plug is M22. Or am I missing something?
    BTW, the door hinge pin tool I bought from you is getting lots of use - popular tool to borrow amongst friends. Should get them to buy their own!
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Hi Gary,
    I just listed the current OEM plugs. You should be able to find a DIN 908 M22x1.5 locally.
    I'm glad that the door pin tool is helping out your friends. That should at least make it their turn.
    Take care, Jimmy
    Feb 2003
    Excellent, thanks for your help Jimmy.
    All the best - and take care - avoid that virus!!!!
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
