Results 1 to 10 of 20
Thread: Ignition breakdown
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Ignition breakdown
    For the brains trust.
    Whilst accelerating under load passing through 3500 RPM the tachometer swings wildly to the stop, and at the same time the car loses power, as if the rev limiter is engaging........ keeping it under 3500 Rpm all normal again.
    I’m thinking rotor, but opinions would be appreciated.
    Tony
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Maybe coil
    Mark
    May 2014
    South East USA
    I think there is a spring on the rotor.
    Maybe not working as designed.
    Nov 2004
    Gold Coast.
    Quote Originally Posted by NZVW View Post
    Maybe coil
    Just checking the Ohm readings in the manual to check it.
    Tony
    Nov 2004
    Gold Coast.
    Quote Originally Posted by Scott A View Post
    Ok I might pull the Dizzy and go over it.....
    Tony
    Nov 2004
    Gold Coast.
    I was thinking it might be the rotor, as it feels like the rev limiter is engaging.......but will check both suggestions, as I try to nut it out.
    Tony
    Feb 2017
    Auckland NZ
    Tony,
    Trust me,
    I'm a Plumber.
    I'm probably incorrect
    Mark
    Nov 2004
    Gold Coast.
    Tony,
    Trust me,
    I'm a Plumber.
    I thought you only trusted Dentists
    Tony
    Feb 2017
    Auckland NZ
    Quote Originally Posted by classic View Post
    Yip..
    Then,
    My,
    Cardiologist
    If I get No fuel or 'Spark' I falter.
    Mark
    Nov 2004
    Gold Coast.
    So not the coil......swapped it for a known good one, same problem....��
    Tony
