Thread: A few oil related Questions
    Dec 2019
    Sisters Oregon
    I overfilled my 72 t
    and the stick reads above the top mark. Is this something I should be concerned about or let it be?
    Second, although my engine was rebuilt at 110 k current 120 k oil pressure when warm is only 60 psi at 4k rpm. Seems low
    at idle its like 20 psi.
    lastly, what is a good temp to begin aggressive driving? ie above 5 k rpm?
    thanks to all of you who have been there .
    I'm still a lost ball in the tall grass.
    Overfilling risks dumping oil into the air cleaner and making a mess of things. Drain a little out. 60/20psi when hot at 4K/idle is OK. You should see ~100psi at cold start at 3K RPM. If not, someone may have put in the later model relief spring. Wait until oil reaches 175F before aggressive driving.
    Dec 2019
    Sisters Oregon
    thank you very much
