Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: 2.0L Build Suggestions
    Embarking on a 2.0S built and have a new set of 2.0S Mahle's. Would like to bump it up in output. Would you go to 2.2, get a longer crank, E or Solex Cams, higher compression ratio, twin plug,....?
    As said before …
    What are you going to use it for/what is your driving style/and does keeping it stock has any pluses for you ???
    cm
    Oct 2010
    Southern Ca.
    The new Mahle S P's and C's are actually 906's , so you will be milling the piston tops or twin plugging . If you don't appreciate the 2.0 why not get a newer car instead of ruining a 2.0 ?
    Jul 2008
    South Florida
    Quote Originally Posted by Richy View Post
    This. The automotive equivalent of buying a mid-century home and turning into a faux- Renaissance revival palazzo.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Quote Originally Posted by Bullethead View Post
    Armchair Architect?
    Also have a stock 2.0S and a 2.2S MFI SWB. No 2.0 will be "ruined" so you will not be sleepless.
    Quote Originally Posted by Soterik View Post
    The best 2.0 I ever had was a 2.5 built by Jeff Gamroth
    Sounds lovely 2.7 P+C's with a 66mm stroke? Must do my arithmetic but don't want to bore the case.
    Senior Member RennTyp's Avatar
    Apr 2006
    Oxford, UK
    I would go with high compression 2.0 pistons (10.5) but stick with the S cam and 40 Webers. Do some flow and porting work on the heads and you should end up with 180hp with a cammy but not "light switch" power delivery. You could go with a 906 flywheel. Will give you the essence of what makes a 2 litre special without the histrionics of a full house race engine. The 2 litre Cup engine builders in Europe have done a load of R&D on these engines in the last couple of years and lots of trick components are now available - pistons and valves in particular.
    Early 911S Registry #888
    Senior Member tcsracing1's Avatar
    Nov 2015
    Somewhere in a galaxy far, far away....
    I turned my 2.0L 69T into a 2.3L using cylinders and jugs from a 1971 and increasing them along with custom pistons/rods, custom grind cams and twin plug.
    www.tcspeed.com
    Jul 2008
    South Florida
    Quote Originally Posted by 50/50 View Post
    Armchair Architect?
    Kidding! Clearly didn't land as hoped. There are many ways to hotrod a 2 liter, build it the way you want.
    Russ
    ESR # 1537
    '70 914/6 GT
