Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
Thread: 2.0L Build Suggestions
  1. #11
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    If you run the Mahle 906 pistons with the 67S heads you will be around 9.7/1 provided that the heads are not decked and it didn't have too many valve jobs. That is without head gaskets...If you ran current gaskets you will be about 9.3/1 approx..
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
  2. #12
    Quote Originally Posted by BURN-BROS View Post
    Great info. Much lower (and safer?) than what I would have expected.
    Btw what would be the data using 67S pistons and since we are at it same question w stock 130hp pistons and heads? I understand there is dome difference, valve pocket and valve size that differs.
    Richard
  3. #13
    Sep 2003
    Camarillo, Ca.
    What head do you want it calculated from Richard?...NVM, glossed over the 130hp heads..
    1967 S piston with a small valve head and No head gasket you are at 9.2/1
    with a gasket you are at 8.9/1 approx.
    This is assuming the dome volume is correct for the 67S piston.
    In the end, If you want to go to 2.2, then I would advise switching to 2.2 heads. It's a better head in every way.
    Aaron Burnham
    Burnham Performance
    805-240-6931
  4. #14
    Quote Originally Posted by Richy View Post
    The new Mahle S P's and C's are actually 906's , so you will be milling the piston tops or twin plugging . If you don't appreciate the 2.0 why not get a newer car instead of ruining a 2.0 ?
    Hey Richy.... I’ll be interested in getting your input further when we undertake my 2.0 rebuild that I believe you are helping me with.
    Maybe I’ll see you next Friday?
  5. #15
    Oct 2010
    Southern Ca.
    Aaron has not worked with the newest generation of Mahle P's and C's . C. R. will be in the 10's .
  6. #16
    The 67/68S piston was officially spec'd at 9.8 :1
    and the 69S piston (looks like 906 piston) at 9.9:1
  7. #17
    Oct 2010
    Southern Ca.
    For awhile and maybe now when you ordered a Mahle '67 S piston and cylinder set you received a 906 set , and the 906's are not 9.8 : 1 , so it really doesn't matter what the specs are . And the air deflectors don't really fit around the bigger 906 cooling fins ; well they do with modification .
  8. #18
    The advertised compression ratios are nominal, the measured numbers are different.
  9. #19
    Quote Originally Posted by 66S View Post
    Oh, I see. Thanks
  10. #20
    Sep 2003
    Camarillo, Ca.
    Dome volume is listed at 38.8CC, how does one attain 10/1 with a 73cc small valve head?
    With the 67 S valves heads get close, but you will loose it once you install head gaskets... 9.3/1 will be the approximate comp.
    Aaron Burnham
    Burnham Performance
    805-240-6931
