Thread: REPRO S Thermostat 2.0S -2.2S
    Sep 2009
    COPENHAGEN, DENMARK
    Reproduction of the 911 2.0S -2.2S - ( 914/6 GT ) Thermostat 901.107.801.01
    casted in Alloy
    Only difference is mine Opens up at 83 degrees, the original 86 degrees, so its not a bad thing , I think
    Priced at 499 € + postage
    for ordering pls drop me a mail at early911parts@gmail.com
    FYI I also did the S oel filter console ,
    https://www.early911sregistry.org/fo...ighlight=marek
    Oil lines are also in the making for the complete set
    For 914/6 Gt user, we are making a handle that looks as org , that we will glue on , on the back ,as the original had a different casting, which incl a mounting bracket
    Well the money are not there, to make new tools , and once mounted on the car, you want see it as rest of the part is as this one
    Marek
    Junior Member
    Feb 2021
    Marek,
    Are the oil Thermostat and oil console in stock?
    Thanks-Ron
    WOW that looks amazing.
    Has anyone run these yet ???
    Jul 2008
    South Florida
    Message sent, I'll take one... also need other oil system components for 914/6 GT
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
