Thread: Help with mystery wire
    I was cleaning up some of the connections in my car, 72 911T, this morning and found this wire coiled up neatly underneath others. It's part of a loom that comes from the front of the car...color green terminated with a connector. Car runs fine ...Just don't know the purpose of this wire so I'm reaching out for help.
    Any ideas are welcome...
    Name:  Mystery 911 wire.jpg
    No telling what you have since none of that wiring is standard. That looks like a ceramic resistor at top of picture, not used for a 72. Also looks like non-standard C.D. box just below it. If car is working well I'd leave well enough alone.
    Ed, Thanks...it's running well. Think i will leave it alone. Yes, it has the Crane Fireball Electronic ignition from the P.O.
    So what is the purpose of the ceramic resistor?
