Results 1 to 7 of 7
Thread: 3D modelers: Unobtainable part needs reproducing
    Dec 2003
    West Los Angeles
    Inside the rockers of our cars are a couple pipes wrapped in sound insulation carrying heat from the exchangers forward. Porsche calls them mufflers.
    The pipes and insulation are usually okay, but there are plastic collars at each end of the insulation wrap. They melt. The 'mufflers' are not widely available here, though they can be found in Europe.
    I suspect I'm not the only one who's opened a rocker panel to find this problem. These seem like an ideal item for duplicating, but since homebrew 3D printing uses melted material to create objects, I doubt it's the correct methodology for this task.
    Ideas?
    techweenie.com
    Jul 2008
    South Florida
    Not sure what high-temp materials 3D printers have available to them, but there are a number of organic polymers that are easily molded or machined. Ryton is good up to 200+ C, Vespel up to 300 C.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Dec 2003
    West Los Angeles
    Quote Originally Posted by Bullethead View Post
    My concern with machining is unit cost.
    techweenie.com
    Jun 2012
    London, Ontario, Canada
    Plenty of 3D metal printers now. Much higher melting points, but also much higher price point.
    Polycarbonate in a 3D printer (we use it a lot) should stand up to the heat just fine. Melting point is 260-300C.
    Ravi
    Early 911S Registry # 2395
    Aug 2005
    Bucks Co., PA, USA
    Putting out feelers for you. Will PM you once I know more.
    ESR #1474
    Sep 2009
    COPENHAGEN, DENMARK
    How many you want !
    been making them for years, for the heather tubes ,I make sold by everybody
    my experience was, that they where, not that much damage by the heat ,more 40 years old , the material simply solidified, and became porous
    also seen a few where the papper where rotten up
    Marek
    Dec 2003
    West Los Angeles
    Quote Originally Posted by Marek View Post
    How many you want !
    Marek
    Hey, Marek! I could use 4. Want to PM me payment info?
    techweenie.com
