Thread: Lower valve cover questions
    Hi All,
    A couple of questions related to lower valve covers:
    1) Can these be removed without excessive loss of oil. So without draining the sump?
    2) What is the correct finish on a 1968 car - plain metal or painted black?
    Thanks, Richard
    Yes, just jack up the side of the car you want to remove cover from. I may be wrong, but I think 68 had a natural mag finish.
    Thanks for the advice
    You can also put a piece of cardboard over the heat exchangers to deflect the oil and prevent it from getting into them.
    John Schiavone
    Connecticut
    Oct 2010
    Southern Ca.
    '68 , '69 , '70 - natural mag finish .
