I would assume that a '70E with a two stage rear defrost would use the same panel as a '70S with two stage defrost. So 16 should be the correct code.
Mine is a '70E with single stage rear defrost. Anyone know the "code" for that combination?
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Clone in Progress
I found a pic on a 911 E build 07/70 with number 16 on the relay panel (It has a relay for the 2-stage rear window defroster) see #18 in this thread https://www.early911sregistry.org/fo...al-Cover/page2
Best Nick
I would need some good reference pictures on a rear electric panel with number 16. I will try to recreate the numbers on mine when I restore it. Anyone who can help?
Best Nick
I had asked this question a while back and included a pic of a relay panel with '16' on it. I think I pulled the pic from an ebay auction. See link below:
https://www.early911sregistry.org/fo...al-Relay-Panel
Post #3 on the below thread for a pretty original '73 car. Panel has an '03' stenciled on it and contains:
- Single Stage Rear Defroster
- Cold Start Relay
- MFI Transducer
https://www.early911sregistry.org/fo...elays-question
FYI - My car is a '70 E (ROW) and it has '05' stenciled on the relay panel.
Iain
1970 911E coupe conda green
2018 911 GTS coupe silver
Early S Reg #3880
Iain,
Does your car have a singel or 2-stage rear defroster?
Best Nick
Nick,
Always a start, but the pic on the 16 is taken from an angel.
Best
Nick
We restored many of these panels but never found any logical explanation for the numbers on it.
Nick,
My car has a single stage rear defroster.
Hope this helps!
Cheers,
Iain
Early S Reg #3880
