Results 1 to 7 of 7
Thread: Gasket For Block-off Cap
    Hi
    It's my understanding a replacement gasket or seal for the anti-roll bar block-off cap PN 901-343-765-00 is NLA. I'll probably have to just bodge one (or more) up. I need a suggestion for a suitable replacement material given its rather hostile environment. The caps were originally installed (very un-factory-like it seemed) with a mass of some tar like substance which just crumbled into fragments upon dis-assembly. Any advice or suggestions will be appreciated
    Thanks & Cheers
    JB
    Success is not final, failure is not fatal: it is the courage to continue that counts. - Winston Churchill
    Early 911S Registry Member #3749
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    I just looked at the two I have. It looks like some type of thin plastic ( or what they have evolved to look like) or similar with the sprayed on undercoating around the edges! I would think, just about anything close would work. Just use some gasket sealer to keep moisture out. cliff
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Thanks Cliff - I guess my next move is off to the FLAPS
    Cheers
    JB
    Oct 2010
    Southern Ca.
    Those are homemade covers , I don't think there was a gasket for the originals .
    Dec 2008
    Black Mountain, NC
    Hawkeye, I have some from early 912's that did not come with the front sway bar, they are solid front / no hole for a sway bar and used what looks like cork for the gasket. If seeing your pic correctly yours have a thru hole for the sway bar. will post a pic a bit later, the gasket was cut round and yes the regular undercoating Shultz.
    I know I have a couple sets maybe more you are welcome to a set if you would like one.
    Best Regards
    Edit: pics attached
    Ok in looking at the pic above I was wrong in thinking it had the cover in it, pics below are from a 68 I parted out yrs ago, my late 65 build 912 coupe did come with a front sway bar before the bean counters omitted them from the lowely 912, now running a 19mm F & 16mm R. I still think this is a round cork gasket maybe .090 or .120 thick cut slightly larger than a diameter that would be larger than the 3 points of the cover.
    Mar 2006
    8903one
    Post two above, came of a 68 Karmann 912......They appear to be a factory part too....
    Hi Guys
    Thanks for your input. I have recently been given access to some 6mm thick butyl sheet 'rubber' which when cut to suit & coupled with an appropriate sealer, could be the the cheapest & most efficient solution. After conversations with some buddies & your thoughts, I feel this would be my best approach as all appears to be a relatively straight forward undertaking.
    Thanks again
    Cheers
    JB
