Results 1 to 7 of 7
Thread: 68 911 rear brake opinions
    Hello
    What are people running on the rears?
    I was hoping to run SC rear calipers but I don’t see any adaptors. And if they did exist what vented rotors would I use. SC vented rotors don’t fit. Too deep.
    Any suggestions?
    I have all SC 930 parts on the front.
    Dec 2008
    Black Mountain, NC
    One "easy" solution is to bring across the SC aluminum trailing arms, gain the SC brakes, ride height adjustment and loose some weight on the trailing arms. Lots of parts available.
    Then there is the while I am in there, bushings, torsion Bars on and on. And other side of the coin being original, but sounds like you have moved on for that.
    You may check with PMB on what he can put together for the 3" spacing
    As a reference I have all of the SC & Carrera bits living in the garage wrestling with the original argument on my 71 Targa, very original one previous owner car.
    Good Luck
    Quote Originally Posted by Jerry L View Post
    Good Luck
    Would be great. But I’m a SWB. the lengths are different.
    Dec 2008
    Black Mountain, NC
    Quote Originally Posted by stubble88 View Post
    Daa! Was not thinking, Will send you a PM on a SWB set up I think may be available thru PMB,
    Damn. Was hoping I was wrong. Haha. Ok awesome. Thanks for your help.
    Do you really have turbo brakes in front???
    No no. Early 930 front suspension with SC brakes.
