Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Where to mount the antenna?
    I finally got hold of an correct hirschmann antenna for my 71 911T (euro spec) LHD Targa.....
    Now I have to work out exactly where to mount it!
    Any info would be greatly appreciated.
    Derek
    Jul 2003
    Santa Cruz, CA
    Manual or Auto? Makes a difference as to which fender side.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Manual.
    I have a template, if I can figure out how to relate the dimensions. Don't suppose you have access to car to create the dimensions from?
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by 911AUS View Post
    Manual.
    Left side then. Auto antennas are mounted on the right side.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Dec 2010
    Southold, NY
    911AUS: Hole for manual antenna on my 1969 Karmann Coupe is 2 7/8" to the rear of the gas filler door opening and on the highest point of the fender as viewed from the front. I took a scaled picture this AM for you, but unfortunately it refuses to upload in the jpg format although I have done this many times in the past using the same camera and jpg format, Give me your email address and I'll send you the photo.
    Dec 2010
    Southold, NY
    Picture attachment is now working.
    My template shows 267 mm from rear most edge of fender, and 95 mm from fender edge at cowl strip.
    Here you go got this a few years ago in a NOS Blaupunkt radio kit along with faceplate correct brackets etc
    Here is a doc I got years ago with a 1969 NOS Blaupunkt radio I purchased on this board came complete with the faceplate etc
    Derek
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Nov 2008
    Finland
    Quote Originally Posted by BOYER73S View Post
    265mm is same on Hirschmann instructions, but it have distance a) 95mm instead of 85mm (seems to be Bosch vs Hirschmann difference)
    edit. I have same Hirschmann instructions like in this FS post:
    https://www.early911sregistry.org/fo...=1#post1032657
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
