Thread: Early knobs
    Early knobs
    Any info would be appreciated re the colors used in heater and fog and other switches/knobs. I see some are red, green, yellow. Some are short, some are long...
    Derek
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Derek:
    Is there a particular year you’re interested in? There were running changes throughout the early years.
    Alan
    N.J.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    It’s for an early 71.
    Euro spec, so hadn’t gone to the newer style rubber knobs found on US cars, still bakelite.
    Quote Originally Posted by lopena View Post
    Derek:
    Alan
    N.J.
    Apr 2003
    New Jersey
    Sorry, Derek, I can’t help you but I’m sure there are plenty of people on this forum who have the information you require.
    Good luck,
    Alan
    N.J.
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by 911AUS View Post
    Same bakelite knobs for 71 with light rods, they just have the rubber surrounds and symbols added over the top. If memory serves on the early cars:
    Green tip Fog
    Yellow Tip Defrost
    Red Tip Hazard
    For 71 of course only the defrost and fog to worry about unless you had the optional Webasto Heat switch. The 70/71 defrost used the larger diam. funky golf tee shaped light rod IIRC. The Fog light still used the green tip slender rod.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
