Thread: A Quick / Easy One
    A Quick / Easy One
    Guys
    The rear stabilizer/sway bar has a washer and cotter pin at the end .
    The washer is part #900 089 010 02 but NLA ....just need the actual specs.
    Believe it’s just a thick hardened 16mm washer ?
    Please advise
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    I don’t think there is anything special about the washer. If it fits use it, kinda thick, it has a large OD, but it’s a 16mm washer.
    Jun 2012
    London, Ontario, Canada
    OD is 29.25 mm. ID is 16 mm. Thickness is 3 mm. Yellow Cad plated.
    Early 911S Registry # 2395
    Perfect.....that’s all I needed
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
