Thread: 901 Gear set
    901 Gear set
    Looking for a used first gear gear set, B or C,
    14 : 37, or 15: 36.
    Any help would be appreciated.
    Rusty
    Alta Classics
    Virginia Beach
    Quote Originally Posted by Rusty View Post
    14 : 37, or 15: 36.
    Just be aware that 1st gear sets for 901 5-speeds are 3 pieces, and must have a reverse idler in the same ratio.
    You cannot use your old reverse idler with a different ratio gear.
    A "C" gear set from a 4-speed Sportomatic will not have the necessary reverse idler for a 5-speed.
    Jon B.
    Vista, CA
    Still in need. Thought we had one sourced, but turns out for a Sporto.
