I've seen some good reviews of the WEVO shifter but less feedback on the Stomski shifter https://www.stomskiracing.com/produc...tealth-edition.
anyone using it (ideally with a 901/911 trans) and have thoughts to share? thanks!
Member #3857
'70 911 2.7
I chuckle to myself every time I see their description. Hard for me to consider it "stealth" with that honking big rubber boot from '73-86 915-equipped cars.
- Arne
Installed one 10 months ago and it has been all as advertised. Shifting is smooth and precise and a huge improvement over the factory coupler where I needed Lewis and Clark going from 3rd to 4th on my 5 speed.
Chuck
Ditto to what Chuck said. Installed one 3-4 years ago. All good.
Tom
Considering this shifter for my 73S. Has anyone installed the Stomski complete shifter? Not the coupler, which I will also do. Trying to decide which brand to go with. Stomski vs Wevo.
Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
I did the Wevo classic on my '73 and have zero complaints. It's an amazing upgrade.
I will add that I needed to pick up a later style shifter base as the late '72 build 915 base wasn't ideal w the roll pins and shims. The latter base has an adjustment set screw which allows you to dial out the slop without using a magical combination of shims.
E911SR & RGRUPPE
'73 S Coupe #306
