Results 1 to 10 of 15
Thread: Signal horn 911 -69
    Signal horn 911 -69
    I have searched but have not been able to find an answer. Which signal horn is right for a 911S -69? I can find three different candidates. I'm happy if someone can enlighten me.
    /Fredrik
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Fredrik:
    Here’s a photo of one of the horns on my U.S.-spec 1969 911S (build date = March 19, 1969):
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    Hi Alan,
    Thanks for the photo. My car has a build date of 10/01 1968. Could it be some other model at that time?
    /Fredrik
    My early 69 has the snail horns.
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    Hi Theunz, When is your car built? It seems that Porsche used up what they had in their warehouse?
    /Fredrik
    Nov 2010
    Darien, CT
    My 69S has snail horns. 100hz and 400hz I think (low/high). They look like these.
    https://www.early911sregistry.org/fo...ght=1968+horns
    69 911S #1379
    65 356 SC #130757
    Ok, so we have two of the snail version and one of the round flat. Were there options of different horns?
    /Fredrik
    Dec 2010
    Southold, NY
    A diagram from the PET. No.1 is described as "Horn, low-pitched BOSCH 290, 335 or 380 HZ and high-pitched BOSCH 345, 400 or 520 HZ." No.11 is described as "Fanfare, BOSCH, 300 HZ and 500 HZ," The Fanfare horns appear to have been available for both the 911 and the 912 in 1969.
    Quote Originally Posted by freddegabbe View Post
    Fredrick, I don’t have the build date but the serial number is in the low 500’s. I suspect late 68 or very early 69.
    1969 911S
    Quote Originally Posted by ejboyd5 View Post
    So here are two different options shown, or?
    I found this when I watched Porsche Classic renovate a 911S -69 in Geneva that makes it three?:
    /Fredrik
