I parted out a 1975 Euro Carrera many years ago before they skyrocketed in value. I have been holding the remaining parts waiting for the right project but that project has not materialized and it is time to offer it up for sale.
1. Motor – complete, original, with hydraulic tensioners added. It was running when removed. It has been stored in a heated garage and still spins. Car odometer said 34732 Kilometers when pulled. Probably rolled once so more like 134,732 kilometers.
2. Transaxle with limited slip - I am guessing original but could not verify as the bottom rib was badly scrapped. In addition the end of that rib is broken off at the clutch cable mount hole with makeshift repair. I have a replacement case piece.
3. Original Gauges
4. Electric console complete with electronics
5. Wire harness from car.
6. Fuel filter assembly
7. Electric fuel pump
8. Accelerator rod
9. starter
More pictures here:
https://photos.app.goo.gl/cu1jS2NkLYzSqG6z5
$48,000 - . buyer is responsible for shipping. I will crate if needed.
