Results 1 to 7 of 7
Thread: Source for correct brown heater hose
    Senior Member Nicklasliljegren's Avatar
    Jul 2012
    Stockholm
    Just like the headline says. I´m looking for a source for the correct "brown" heater hose from heat exchanger to air shroud, one on each side equal length (part no 90121119400) to my 911 E 1970.
    All help is appreciated.
    Best Nick
    Senior Member NickP's Avatar
    Mar 2006
    Solana Beach, CA
    I’ve gotten the heater hose from Newco. https://www.newcoproducts.com/index....egory&path=421
    Nick.
    Nick Psyllos
    S Reg & R Gruppe
    1973 Euro 911S
    1972 911T to ST
    Aug 2013
    Westlake Village, Ca.
    Looking for this hose also. I noticed that the Newco hose doesn't have the aluminum inner liner?
    Scott
    303581
    Have you tried stoddard and/or sierra madre.
    Hi guys, perhaps the below list of part numbers and dimensions will be helpful, quite a few hot air hoses for Porsche and VW in the original aluminum / paper construction style are now available.
    901 110 295 00: 28 x 560mm (Shiny Black)
    901 110 296 00: 35 x 550mm (Shiny Black)
    901 108 291 00: 35 x 780mm (Black)
    644 211 921 05: 50 x 270mm (Black)
    911 211 274 00: 50 x 720mm (Tan)
    911 211 274 00 B: 50 x 720mm (Dark Brown)
    028 129 087A B: 50 x 1080mm (Dark Brown)
    930 211 196 00: 60 x 130mm (Tan)
    930 211 622 01: 60 x 330mm (Tan)
    930 211 622 01 B: 60 x 330mm (Dark Brown)
    901 211 194 01: 60 x 380mm (Tan)
    901 211 194 01 B: 60 x 380mm (Dark Brown)
    901 211 195 01: 60 x 458mm (Tan)
    901 211 195 01 B: 60 x 458mm (Dark Brown)
    911 211 522 00 B: 60 x 1110mm (Dark Brown)
    911 211 522 00: 60 x 1110mm (Tan)
    644 572 971 00: 60 x 1500mm (Tan)
    See this post for photos of one of these hoses installed on a 914.
    Jul 2012
    Stockholm
    Ha!.I took a look at some pics on very low milage cars and factory pics posted here on the forum. I do not think they were brown when they were new. It must be from age patina. They were a sort of dull gray / black.
    Thanks for the help
    Nick
    Jul 2012
    Stockholm
    The heat exchangers hose from Porsche have a shiny black exterior and is not a match. I therfore is going to use the hot air hose (PN 914-572-123-10) from Porsche and it matches the original one (dull black paper on the outside).
    Best Nick
