Results 1 to 4 of 4
Thread: Hole behind gas tank
    Dec 2013
    Connecticut/Florida
    Just checking...I can't seem to see what the hole at the center of the rear of the gas tank is for. My car is a 1971 with Fuel Pump at the rear.
    1971 911S Coupe - Gemini Blue
    May 2014
    South East USA
    i can get you more info later.
    my car is a 1971, but the fuel pump is up front...And the sheet metal hole is where wires goes down to the pump.
    Hi Simon, are you referring to the ~1” diameter hole in the center of the panel directly behind the fuel tank? If so, my research for my ‘69 restoration showed that the wiring for the front mounted fuel pump passed through that hole.
    HTH,
    Rick
    Dec 2013
    Connecticut/Florida
    Great. Thanks.
