Results 1 to 9 of 9
Thread: Fuel PUMP replacement 2.0S
    Aug 2012
    France
    Greetings all,
    The front behind the gas tank fuel pump is leaking through the 2 electrical wires joints. Hereafter you may find Pics of the pump.
    I searched for the ref number printed on the pump, but no joy. I 'd like to keep the same installation setup.
    Engine is 2.0S 1968 running on Weber 40IDS
    I do have as spare parts a 3.0SC fuel pump which could be mounted same way, but I do not know if compatible or not with carbs.
    Also have a gold FACET, but needs to be mounted vertical and that does not fit behind the gas tank, so need to do a bit of work to install it.
    Any help/pics/ref numbers are welcomed
    X
Size:  99.8 KBName:  IMG_3439.jpg
    O-G 26 - Early911S 2407
    Aug 2012
    France
    I found one that may fit :Pierburg 7.21440.51.0
    Have ordered one - will see.
    Cheers
    These are very common pumps used for US, European and Asian carbureted cars and trucks from 1955-. They will work, but you wouldn't want the later models that have threaded (instead of push-on) inlet and outlets.
    AC Delco EP42S
    6-9 psi, 20 gph, 3/8 in. Hose Barb Inlet/Outlet
    Here are 2 common cross-reference numbers:
    GM 6472382
    Bosch 69405
    The genuine GM parts are available from Amazon for $49.78. You should be able to find one local to you.
    Aug 2012
    France
    Jimmy, you are a star ! thank you !
    Quote Originally Posted by JimmyT View Post
    AC Delco EP42S
    GM 6472382
    Bosch 69405
    I don't believe your car came with that fuel pump , I'm used to seeing a Bendix pump on the engine compartment relay board . Similar Facet pumps are available .
    Aug 2012
    France
    You are right about the fuel pump, not original - have a facet one, but it I can use the existing setup (that works perfect as is) that would be better.
    Cheers
    Aug 2012
    France
    Replace it with a GM 6472382 and works pretty well ! Thanks !
    Sep 2012
    That is not the original fuel pump. Correct NOS fuel pumps are not rare and are not expensive. Somebody gave me a NOS 1966 Hardi HZP in the box just this week.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    Aug 2012
    France
    I know, it replace the exiting mounting, it works well and am no purist.
