Thanks, Ravi, great explanation. I am familiar with this system, just never heard it referred to as "anti-backfire"It’s the system that involves the microswitch, the speed relay in the rear electrical console and the cutoff solenoid at the end of the mfi pump.
On the MFI cars. when you lift off the throttle at higher rpm, the throttle plates slam shut, but the pump keeps spraying fuel at a high rate until the pump catches up and provides only idle fuel flow. That leads to a super rich condition with lots of unburnt fuel and often a backfire or two. To counter this, Porsche installed a circuit that does the following. It has an speed relay (technically engine speed relay but Bosch calls it a speed relay) that always puts out 12V whenever the rpm is between 1300 and 1700 rpm. The speed relay gets its rpm signal from the black/purple wire on the dizzie. This 12V signal from the speed relay is applied to a solenoid on the mfi pump that pushes the rack to its fuel cutoff point. Now obviously, you don’t want the solenoid active when you are on the throttle, so Porsche installed a microswitch that feeds the speed switch 12V signal to the mfi solenoid ONLY when the throttle plates close.
Net result? When you let off the throttle above 1700 rpm, the MFI pump still sends fuel (avoiding a massive lurch) until 1700 rpm where the MFI rack is pushed by the activated solenoid and the fuel cuts off. The fuel comes back on below 1300 rpm so you don’t stall. At that point you are almost at idle and you just have idle air-fuel ratios, so no backfire.
The circuit can be cantankerous. Hence people pointing fingers at it. Speed relays fail due to vibration and corrosion of the leads. Mine has been repaired by Bob Ashlock. Bosch also sells a modern replacement. It uses an integrated circuit. I am using it at the moment. My pump is rebuilt, but it is the original solenoid. Microswitches fail. Mine is new. In failure modes, you just get backfires. But if the solenoid sticks, you get a cutout of fuel.
In my case, any intermittent electrical glitch in the car should also occassionally show up when not at idle. The car has mever missed a beat in 1700 miles. So I discount that. It has to be something that only occurs at idle. Hence my focus on the speed switch circuit, but the solenoid in particular.
Ravi
