Thread: FS: 1965 912 Engine
    FS: 1965 912 Engine. ** SOLD **
    1965 912 engine fitted for a 356. Less than 10l mo. Since rebuild, runs smooth, strong and cool . All 912 components with exception to carbs ( Zenith 32 NDIX ) flywheel, aluminum oil cooler, 6V Elect.
    Great leak down #’s between 1 & 2 %
    $12500
    video of running engine https://youtu.be/wgQaKRpBqu4**
    Best Max Handley
    Quote Originally Posted by spyderwerks View Post
    1965 912 engine fitted for a 356... All 912 components with exception to carbs ( Zenith 32 NDIX ) flywheel, aluminum oil cooler, 6V Elect.
    It also has a 356 mechanical tach drive, and a 180mm pre-60 clutch.
    Jon B.
    Vista, CA
    Senior Member acoupe's Avatar
    Jun 2014
    Lincoln,NE
    serial number pad looks like it`s been machined/resurfaced
    3rd piece serial#
    [QUOTE=acoupe;1075892]serial number pad looks like it`s been machined/resurfaced[/QUOTEno
    No way , it’s original . Get real !
    Best Max Handley
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    What’s the case type? 616/36, 616/39, or 616/40? That is a unique look to the stamping area. I’d say it’s highly unusually to have ground and restamped the third piece but anything is possible.
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    Quote Originally Posted by jt912 View Post
    616/36 all 3 pieces are #’s matching . For the sake of argument it really doesn’t matter as it’s built for a 356.
    Best Max Handley
