Hugh Hodges
73 911E
Melbourne Australia
Foundation Member #005
Early S Registry #776
Hugh is correct. 9282xxx would be Airport gears. + the type number matched, 9282xxx =901/52, 9284xxx =901/54.
Y'all are both correct, someone had handwritten "hillclimb" as a translation on my kardex file I have. Gearbox is "901/52" as well.
EarlyS Member #3823
Typ 901 #0562
356 Registry #53935
1956 356A 1600N #57976 - "The Battlewagen"
1968 911 S #11801199 - Canary Islands Sports Purpose
1970 911 S #9110300783 - Pastel Blue Survivor
1994 964 Speedster - 1 of 2 Amazon Blue
Previous:
1951 356 Pre-A Split Window Coupe #11260 - Maroon
1966 911 2.0 Cup Car #305515
1968 911 T/R #11820721 - ex-Linge/Bauer & Strähle KG
1970 911 T #9110122684 Tangerine Hot Rod
1972 911 T #9112102781 Aubergine/Tan
Chassis 11810620 has engine 380026, type 901/30 and is one of the 28 Group 2 Rally-Kit cars.
Unusually, it is listed as having been supplied with a standard 901/05 gearbox number 3282292, no longer with the car.
The car is beninning to undergo a full restoration, back to original spec and, for interest, when it was stripped down we found it had a 902/1 gearbox with 39/65 date stamp. However, the car had been sitting still for a very long time, and all of the details specified in the surrounding Rally-Kit literature were present and correct. This must have gone in early.
Competition Nadellas, ZF limited slip, straight through main shaft, lightweight flywheel, competition clutch etc...
Looking at the 4 combinations suggested by Porsche in the Sports Purpose document, this car's gear ratio set up matches none of them perfectly. For reference, what we have is AA, E, I, O, and V; which corresponds to the first three gears of the Hill Climb set, then what was used as 4th for Airfield/5th for Hillclimb and finally a taller gear that equates to 5th from the Nurburg Ring set.
More research is needed to understand the early history of this car, but we know that the US serviceman listed on the Kardex as the first owner, was not in Germany in May 1968 when this car is shown, on the Kardex, as having been built. No delivery date is shown. But the car had done 27k kms by 4/69 when it was attended to under warranty at Rittersbacher.
Other options include "Rallye Austrustung ohne Räder", 100L Tank, Sportkit 1 (loose), 840 Watt generator and a front stoneguard. Curiously the Kardex shows delivered with no wheels or tyres.
S-Reg #3160
This may have appeared elsewhere on the forum, but possibly useful here.
S-Reg #3160
quicky table of special trans types
901/50 901/70 901/75 901/80 standard special option
901/51 901/71 901/76 901/81 hillclimb
901/52 901/72 901/77 901/82 airfield
901/53 901/73 901/78 901/83 fast race
901/54 901/74 901/79 901/84 Nürburgring
Hi Eric,
more information about 11800208 for your list:
11800208_4080192_9282005_Rallye-Kit, SKII, LSD, 901/52 airfield gear box, 100ltr tank, roll bar, factory lowered car
Best
Claudius
Claudius,
Thanks for the additional information. I've added a summary to the end of Post #1 including these details for 11800208 along with the details on the sports purposes parts for the other cars where known. Two tables were generated. One for the S and L cars and the other for the TR cars.
Eric
Any info on the Bernd Stelzig car? It looks to be a T/R. R Rally muffler, 911R flares. Sadly a fatal crash..
Brad Davis
RGruppe #691
Early 911S #1547
Peter Kane
'72 911S Targa
