Results 1 to 10 of 11
Thread: 3" spacing aluminum Brembo calipers - fully restored set with titanium bolts
    Dec 2014
    Motor City
    Offering this beautiful pair of Brembo alloy calipers with 3" mount spacing. This set is assembled with titanium bolts. This is an EARLY type of these calipers (late 70's) with Brembo text on the outboard caliper halves and symmetrical spacers.
    These calipers have received a full restoration. This type is a popular bolt on upgrade: they utilize a larger pad and are about 4 lbs lighter than original cast iron versions.
    My full restoration calipers are completely disassembled, cleaned, tanked, checked for cracks, threads OK'd, surface blasted, anodized, baked, and rubbed with petroleum jelly. Original Brembo pistons restored, polished). Premium rubber seal kit (ATE pressure seals and Brembo type dust boots) and new split-body o-rings. Assembled with proper assembly lube (ATE / Porsche paste). New correct bleeders.
    Available with pads and adapter lines for a true bolt on upgrade. This set is $925 delivered in the USA. This pair of calipers has my last set of titanium bolts until I have another batch of bolts made.
    Rob
    Dec 2014
    Motor City
    I had a question - the bleeders are steel Brembo units. Not titanium like the main body bolts. But, I do have some titanium bleeders available.
    Rob
    Dec 2014
    Motor City
    Offers invited!
    Rob
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    R` these for vented or solid rotors?
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Aug 2016
    NE Ohio
    Subscribed, may be intererested if will fit 67 normal but w slotted rotors
    Dec 2008
    Black Mountain, NC
    Not Speaking for Brickless, but throwing out free bump and one point of reference, I have a set that are for vented rotors, not saying they are the same BUT may well be.
    Best Regards
    Dec 2014
    Motor City
    Sorry for the delayed reply folks. I just didn't get the notifications.
    These are built for vented rotors. These can be run on solid rotors by removing the spacers and installing shorter bolts, a bit of work but not much.
    I have other sets that are built up for solid (non vented) rotors. Thanks!
    Rob
    Dec 2014
    Motor City
    Still available, xmas deal available
    Rob
    Junior Member
    Sep 2020
    Calipers
    I'll take them, shipping to NorCal
    jonsduckworth@gmail.com
    Dec 2014
    Motor City
    Quote Originally Posted by jonduckworth View Post
    Great. Sent you an email!
    Rob
