Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 161 to 170 of 171
Thread: Frank and his 911R
  1. #161
    Aug 2012
    France
    Awesome.
    What kind 3d printer are you using ?
    Thinking of buying one, but hard to choose one as there are so many out there.
    Cheers
    Xavier
    Quote Originally Posted by Frank63 View Post
    My air filters are ready .
    In order to get more space above the intake, I used the lower 35mm of two original air filter trays and welded them under the cut-out K&N filter lower parts, sandblasted everything, chromated it, smoothed off the transitions and finally painted black with 2k paint. The filter tops are 3D printed. But I sanded away the Porsche lettering, which somehow turned out to be too much.
    Of course, the hood grille didn't fit anymore, so I had to drive the contour of the high air filter into the grille. That went quite well with a round dent removal hammer and a leather sack.
    In my opinion, the engine runs more freely than before, it hasn't lost any torque and the engine sound is now simply perfect.... ��
    A positive side effect: The filter weight is 1.4 kg less than the previously installed air filter box
    O-G 26 - Early911S 2407
  2. #162
    Member Frank63's Avatar
    Jun 2013
    Siegen / Germany
    Quote Originally Posted by Xavier PJB View Post
    Awesome.
    Cheers
    Xavier
    It was printed on an industrial printer in a friends company. The printer can print up to 120cm in 3 dimensions and uses various materials
  3. #163
    May 2011
    Chelsea, Québec
    Just simply awesome work and skill level... I'm humbled to an extreme level...
    Member #1616
  4. #164
    Aug 2012
    France
    Thank you
  5. #165
    Jun 2013
    Siegen / Germany
    A pair of lightweight door handles. Looks pretty good and saves 320 gramms
  6. #166
    Jun 2013
    Siegen / Germany
    I mounted new headers, because the Friedrich Motorsport headers with 39mm size were too large. I cut a pair of 34mm headers out of old SSI heat exchangers and weldet in oxigen sensor threads for carb jet fitting.
    With the smaller headers the car runs much better
  7. #167
    Jun 2013
    Siegen / Germany
    Yesterday we had a rallye event with 5 hours of driving. My son Sebastian was navigating and we had lots of fun. The car runs great and performs really well.
  8. #168
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    is this an invitation to come over and have a drive…?
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  9. #169
    Jun 2013
    Siegen / Germany
    Quote Originally Posted by haul View Post
    No problem
  10. #170
    Sep 2007
    Norway
    I did not see this thread until now.... Congratulations with a really impressive build, car is amazing, detalies fantastic and craftmanship really inspirering for all of us! Thanks for sharing and if you are out on a Scandinavian road trip please make a stop in Kragerø in south of Norway
    '67 911S Sunroof, Polo Red(Project disguised as a G-model)
    '67 912 Sunroof, Light Ivory(Alive and kickin')
    '67 912 SWTarga, Signal Red(Project in the making)
    X: 67 911 Coupe + 67S Targa, 912, 924, 944, 928, 356
