Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: How to fix a hand throttle!
    Jun 2010
    Garden State
    A tedious job well done. Now is the time to insure throttle plates are wide open with pedal against floor stop.
    Sep 2021
    Thanks for your valuable information.
    OK thankful for this thread. I just got through with the replacement of that broke nylon/plastic piece. I did remove the driver side seat. This made the access much easier. I also had to remove the 13mm nut on the hand throttle to get the handbrake assembly out enough to access the broken part. Replacement was fairly easy. I had noted in the previous thread that to be careful not to lose the locking spanner thingee, so a stuffed the the area around with a rag just in case so it would not drop down in the tunnel. After getting the handbrake assembly back into place, I had to get this new piece on to the accelerator cable. Not as bad as I thought considering I did it through the small adjustment hole. All done and working again. Thanks again everyone.Name:  IMG_2012.jpg
Size:  95.0 KBName:  IMG_2013.jpg
    Apr 2003
    Portland, OR
    My throttle rod bushes have perished. To confirm, in my 1973, there are two: One accessed under the shifter and the other at the rear coupler cover. Coprrect?
    Harry
    Member #789
    2009 MB C300
    and one under the handbrake.
    Apr 2003
    Portland, OR
    Ed. Thanks for the help and advice.
    Harry
    Member #789
    2009 MB C300
    Apr 2003
    Portland, OR
    Just replaced all three bushes. In the process dropped one in the tunnel and after an hour I gave up and bought a fourth one. Not hard but a big pain. Hope I never have to do this again.
    Harry
    Member #789
    2009 MB C300
    Great guide thank you! It is certainly a "needle hands" job. I've never seen a car that has these bushings still intact, and the replacements are stupidly expensive. Still, it's worth it because I don't like that sound of the throttle rod rattling against the tunnel every time you step on the pedal.
