Results 1 to 8 of 8
Thread: WTB: Bosch distributor 0 231 121 006 JFR 6
    As the tile says I am looking for an early cast iron 006 distributor. My engine got a yellow badge somewhere during its life and I would like to bring it back to original.
    Still looking. Does not need to work, core parts also acceptable
    bump die dump
    The Netherlands
    Not sure if you have found one, if not:
    https://www.ebay-kleinanzeigen.de/s-...76908-223-8474
    I can help if you need to talk with the seller.
    Cees
    Oct 2010
    Southern Ca.
    I have an 0231121001 JFR6 in great working condition . The distributor is the same , the difference being the rpm limit rotor , the 001 came with one and the 006 did not . I would trade for the distributor you have and give you some money .
    Quote Originally Posted by Richy View Post
    He is looking for a 006 (which has a smaller shaft and takes a 356 rotor?)
    Richard
    Thanks Cees, will give it a shot. Richy, I will keep that in mind, thanks. Richard, thanks for the clarification.
    Still looking. Rough 001 or 002 core also considered for a side project. Would like to do some experimenting with stealth 123 internals put into an original housing
    Bump to the top
