Thread: Door handle salvage and repair
    Sep 2020
    Long Island, NY
    A new friend stopped by to pick up some parts and also noticed my driver door handle was loose. I noticed this as well, and thought "I'll get to it". After carefully removing the door card, I thought (according to the parts catalog) I would just need to snug up a couple of lock nuts. Not the case.
    At some point in the car's history, a few make shift repairs occurred in order to tighten the door handle.
    On the lock side, a washer and a wood screw kept it in place, along with a small glob of JB Weld.
    No wonder the door handle wasn't tight. At some point the stud was broken off, drilled out and a screw put in.
    On the front of the handle, I found the stud was jbwelded on, and to cover the fix and still get it to snug, a series of washers:
    I tried to run an M4x.75mm die over the front post, seeing that the studs are an M4x.75
    The post, of course, just snapped off.
    So, I decided to drill both secure points with a 3.2mm drill bit (perfect to accept a M4x.75 bolt):
    There is quite a bit of "meat" on the handle, but mind your drill depth. I drilled to a depth of 10mm in both holes.
    After tapping and cleaning the holes, I ran to the hardware store and picked up two M4x.75x10mm bolts (uses a 7mm head):
    Sep 2020
    Long Island, NY
    Once prepped, I re-lubricated the door internals since the door card was off.
    I then applied blue thread lock on both, used an M4 flat and lock washer
    Using a 7mm 1/4" socket with a long extension, snugged up both bolts:
    Now the handle is nice and snug, and I didn't have to bid on the expensive door handles on ebay :-)
    Handle salvaged, and installed properly. I am sure I missed something - let me know, if I have.
    Happy door handling.
    Nice work. Terrific photography.
    Dec 2010
    Southold, NY
    Good work and satisfying as well.
    fantastic work - great write up, thanks!
