Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: battery tender
    battery tender
    Do Sonnenschein gel batteries require a special maintainer or will my Interstate 12V lead acid maintainer be ok? It has a maximum output of 12V and shuts off to float when at full charge,1.5 amp I think.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    Oct 2008
    Burford, ON, Canada
    That does not sound correct. The nominal voltage of a fully charged battery is about 12.8 V. To charge such a battery requires an output near 13.8 or 14 volts; the normal output of an alternator at driving RPM's. Full charge is normally determined by the voltage, not a current.
    Jun 2012
    London, Ontario, Canada
    Nope. Too low. Even 12 is too low. A fully charged battery is 12.8 V or so. You need an AGM maintainer. It will go higher in voltage for short periods of time (14.7 or so) and then ramp down voltage and trickle charge on a cycle (i.e. not continuously). Just invest in a CTEK or something equivalent. Cheap insurance. Much cheaper than a new battery. I use one on my 911 and also the same one my Macan (which is also an AGM battery) because most of my drives in the winter are short and electricity intense (lights, heated wheel, heated seats, rear defrost etc) and the CTEK tops up the battery once a week.
    The Macan is 5.5 years old and the battery still load tests at 96% capacity.
    Ravi
    Early 911S Registry # 2395
    Which model CTEK? I just switched from Lead acid to Sonnens But wont be driving the car till spring.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    Jun 2012
    I have a CTEK MUS 4.3. I've had it for at least 8 or 9 years so it may not be made any more. But any charger which has a specific AGM mode would be fine. On mine, the snowflake symbol mode is the AGM mode.
    EDIT: I see it is still available. But so are many others.
    Thanks Ravi!
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    Sep 2012
    Colorado
    I have used El Cheapo $20 battery maintainers from wherever for years, all different sorts of 12v batteries. No problems ever.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    Newer Ctek chargers go through cycles including one to renovate older batteries, I just got a 4.3A polar version.
    Member 66DC's Avatar
    Apr 2011
    Washington DC
    I'm using an AGM-specific BatteryMINDer for my AGM battery. 8+ years later it's still cranking strong.
    1966 911 coupe, Granite Green
    Mar 2016
    U.K.
    Quote Originally Posted by NorthernThrux View Post
    I have a CTEK MXS 5.0 and the instructions state that normal battery program (the car symbol) should be used for Gel batteries. The AGM option is for "AGM batteries like Optima and Odyssey".
