Results 1 to 10 of 12
Thread: Radio help
    Dec 2013
    Connecticut/Florida
    Radio help
    Hi
    I have a 1971 and I can’t figure out the radio speaker plugs. My rear radio looks like the picture below. One of the holes has a clear plastic surround to it. I have a 2 round prong plug. But only one prong will fit into the hole. The other hole is too small. Are there plugs with different size prongs?
    1971 911S Coupe - Gemini Blue
    Sep 2012
    Colorado
    What is the radio? That does not look like a period Blaupunkt.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    I've never seen a plastic "surround" like that. Can it be removed?
    May 2014
    South East USA
    Can you take a photo of the entire back panel?
    Dec 2013
    Connecticut/Florida
    Apr 2014
    Germany
    1970 911 2.2 S Coupé Bahia Red - Early 911S Registry #3174
    Sep 2012
    Colorado
    First, that is a European radio; was your car a Euro delivery car? Second, while I am no expert, from the model and serial numbers, I believe that radio is probably from 1969; are you sure it is original to your car? Third, the plastic 'surround' around each of the two speaker plug receptacles is normal, meant to insulate the speaker plug from inadvertently grounding. However, I still don't understand the back of your radio; normally, the two speaker plug receptacles are both the same size and are oriented vertically with respect to each other, usually along the left rear edge.
    Rich Spritz
    1969 Porsche 911T
    Dec 2013
    Connecticut/Florida
    So it’s clear a B is for my year...1970/1971 and based on the Pelican forum it looks like plug is different
    From
    To
    Letter From To
    Letter
    1950 1956 See * 1965 1966
    W
    1956 1957
    K
    1966 1967
    X
    1957 1958
    S
    1967 1968
    Y
    1958 1959
    G
    1968 1969
    Z
    1959 1960
    Q
    1969 1970
    A
    1960 1961
    D
    1970 1971
    B
    1961 1962
    E
    1971 1972
    C
    1962 1963
    T
    1972 1973
    D
    1963 1964
    U
    1973 1974
    E
    1964 1965
    V
    1974 1975
    F
    Quote Originally Posted by raspritz View Post
    ...the plastic 'surround' around each of the two speaker plug receptacles is normal, meant to insulate the speaker plug from inadvertently grounding. However, I still don't understand the back of your radio; normally, the two speaker plug receptacles are both the same size and are oriented vertically with respect to each other, usually along the left rear edge.
    Just looked at two B series euro Frankfurts I have on the shelf and both look like the OP's with the same speaker plug orientation and a plastic surround only at the top speaker hole. Funny, I'd never noticed it before.
    Apr 2014
    Germany
    You also might want to look for this to attach the speaker
    https://www.koenigs-klassik-radios.d...ker_30144_1548
