Thread: WTB: Sway Bar Arms & Drop Links, Euro Front Right Indicator Housing
    I need these parts for a LWB '69
    Front Through Body Sway Bar Arms & Rectangular Washers & Drop Links
    I would be interested in any of the following parts if you happen to have them as well as the above...
    2x MFI Throttle body rods, the ones that go from the central butterfly to the outer ones ~120-130mm long
    7x triple square door bolts, not mangled
    clutch stop for foot plate
    black ash tray
    2x luggage compartment light lenses
    2x snail horn mount arms
    RHS door crank actuator (the crank that connects to the door handle in the armrest with 4x mounting bolts)
    ivory rear side window edging trim
    RHD armrests
    Aug 2011
    north of the 49th parallel On Can.
    I have this 19mm that was in my 69 not factory original. It was made by RACEWAY many moons ago.
    Don't have any hardware, will need new rubber for the links. Sell what's in pic.
    May 2006
    CT
    I can provide the following:
    black ash tray
    PM me with your email for details
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Sep 2009
    COPENHAGEN, DENMARK
    I can help you with
    but depends where you are from
    Marek
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
