Results 1 to 9 of 9
Thread: Paint code for silver cookies
    Junior Member
    Mar 2015
    Northern Ireland. UK
    Hello all,
    It's a while since I've been on here but I'm hoping you guys and galls may be able to answer a question no-one can on this side of the pond.
    I have a US 1973T 911 in restoration and need to refinish a set of year correct cookie cutter wheels to go with it.
    I have been unable to identify a specific paint code for the silver colour.
    Has anyone looked into this?
    It is possible that it may be a colour called 'Steel Blue Metallic' but the body colour with that name looks way to blue to be right.
    Best.
    Al.
    Oct 2008
    Burford, ON, Canada
    No, it would not be Steel Blue. I would go with the simple silver metallic 936.
    What do you make of this, Dave? Just marketing-speak? Or only applicable to later years?
    Name:  Cookie Cutter.jpg
    Oct 2008
    Burford, ON, Canada
    Those were from 1974, and unknown how long they were available.
    Junior Member
    Mar 2015
    Thanks Dave,
    That advert was where I got the paint description from so will ignore.
    I'll go with Silver Metallic 936 then.
    Next question is around finish. I guess they would have been painted with gloss cellulose in '73? My first 911 was an '82 SC with cookies and they seemed to have a very heavy lacquer on them. It was cracked off in places and water/dirt had crept in under the clear layer. It was almost like a plastic coating it was that thick.
    I'm thinking modern 2-pack with a gloss lacquer. The underlying texture of cookies is actually quite rough so I think gloss will be OK if not put on too think.
    All thoughts/advice welcome!
    Al
    Original cookie cutters that I've seen have always struck me as less than glossy. I believe there was discussion about this before.
    Aug 2011
    Eugene, OR
    From memory (I worked in tires and wheels back in the day), the matte finish silver was typical for most German cast wheels of the early '70s. Specifically ATS, Ronal and others.
    - Arne
    Junior Member
    Mar 2015
    OK, thanks guys. I'll go with a couple of coats of matt lacquer which tends to give a slight sheen.
    Cheers,
    Al.
