Thread: Help - Aseembling Clutch Fork/Pivot Bolt Assembly '70E
    May 2006
    CT
    Getting ready to mount the gearbox to the engine for my '70E project. I went to install the clutch fork into the gearbox and I am unsure of the required parts and order of assembly. I have the upgraded pivot bolt, new spring and washer. I looked over several articles here and on Pelican and am guessing at the order of assembly shown in the attached photos. I assume this assembly then threads into the inside wall of the bell housing. Do I have all the required parts? Are they assembled in the correct order?
    Thanks in advance.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    May 2006
    CT
    I just took a look at another 911/01 gearbox I have on the shelf. That one has the upgraded pivot bolt but the leaf spring and the washer order is reversed and the washer is flipped with the wide side toward the bell housing.
    I am guessing that that is correct.
    Tom Butler
    1973 RSR Clone
    1970 911E
    May 2014
    South East USA
    my best memory, tom is correct,
