Thread: Speaker installation
    Dec 2013
    Connecticut/Florida
    Hi
    Just want to confirm the ordering and placement as I continue my rebuild..... I recall that the dash is installed first and then the speaker from the top side. Speaker is not under mounted and not installed before the dash. Correct ?
    1971 911S Coupe - Gemini Blue
    correct. just replaced speaker from the top with dash in place.
    Once you let the smoke out, It's hard to put it back in
    Quote Originally Posted by Simonjjb View Post
    Hi
    On an original dash, yes. Lots of aftermarket dashes aren't as well designed.
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by LiveFromNY View Post
    Yeah...so the replacement Porsche dash has the issue as well....grrrr. You can't fit speaker if dash is in, unless its undermounted
