Thread: 3.2 to SWB
    3.2 to SWB
    Hi
    I have 67 car without engine and gearbox. I got an offer for 3.2 stock engine and gearbox fro G model
    How difficult to connect the driveshafts? Any other issue?
    Bruno
    Oct 2018
    Orange County, California
    Sounds like you have the makings for a fun build...are you considering upgrading transmission, suspension, and brakes?
    1957 356A Cab Condor Yellow
    1970 911E Targa “CONDA G”
    1970 911T3.2 “Meatballs”
    1972 911T2.5 “AWBRGN”
    1972 911T Targa Glaserblau
    1976 911S Talbot Yellow
    Already has late G model brakes in the front. Thinking to make a high compression 3.2 with some S-mod cams and Webers 46
    G model had both the 915 and G-50 trans (beginning in 1987 or 1988)...if your 3.2 has the later G-50 you'll need mods (or possible entire replacement?) to the torsion rod tube....or sell the G-50 and source a 915 trans.
    Feb 2004
    Texas Gulf Coast
    First off in my opinion there is likely such a thing as too much power in a swb car. ...I'm building one now with a 2.8 twin plug race motor that has been de tuned with smaller port heads and milder cams. I am concerned that it will be too much for the car. ...never really said I wish I had less power in a car so maybe I am wrong.
    Secondly if you utilize the 915 box you need to "relieve" the rear seat pans for clearance and then source some 914 output shafts to use on the 915 box (hopefully you have one that the splines line up with) If you use the 914 output shafts they should connect with your axles.
    -Jay
    Seabrook, TX
    '68 911T project -The Rat
    '74 911 3.0 EFI Twin Plug toy
    '80 Weissach 3.2 S.S. Grocery Getter
    '70 914/6 GT vintage race car
    The engine comes with the 915 gearbox. I also have a late 901 (911) gearbox from a 1970 car. Maybe I can use this gearbox as well?
