Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 49
Thread: 2.2 Need More Power
  1. #11
    Sep 2012
    Colorado
    200 hp for a 2.2 for $20K? Those numbers have nice symmetry, but I am not sure they add up. The car is a mess that you want to restore back to near-original, the matching numbers engine was just redone and now you want to do the top end again to build a 200 hp "firecracker engine", and there is nothing you can do to "strengthen" the 901 transmission. As a Porsche Club Racing racecar for someone with deep pockets, sure. As a car for "street and spirited driving", I don't get it.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
  2. #12
    Junior Member Uwon's Avatar
    Mar 2011
    Ontario, Canada
    Quote Originally Posted by Richy View Post
    Yes . minimum boat-tailing on a mag case . The 2.4 crankshaft will fit but the compression ratio will be too high with 2.2 S P's & C's , and too low with 2.4 S P's & C's . Unlike 2.2 liter crankshafts all 2.4 liter crankshafts are counterweighted and balanced to a point . Only the 2.2 S & E crankshafts are counterweighted .
    Richy, now you are confusing my old brain. Why would a 2.4 crankshaft with 2.4 S P's & C's end up with too low compression ratio? Isn't that what the '72 S has out of the factory? Or are the heads different between the '70T and '72 S?
    TIA
    Johan
    Living well is life's best revenge- George Herbert(1593-1633)
    ‘71 911T, 2006 C2S, Carrera RST Hot Rod http://forums.pelicanparts.com/porsc...rrera-rst.html, A4 Quattro
  3. #13
    Feb 2007
    San Diego
    I did a 2.0 914-6 last year, went 87.5mm slip in pistons (made it 2.45L) with a 66mm counterweighted crank, solex cams and bunch of special sauce throughout and it made 210hp. Reved like crazy.
  4. #14
    Mar 2011
    Ontario, Canada
    Quote Originally Posted by raspritz View Post
    Yep, I'm nuts, I know. The price was right even if the motor had been a basket case. So I'm starting off with a "bargain" so to speak. 200HP is not that far off the '70 S at 180HP so i would assume that a refreshed 901 should handle the additional power. I'm told that there are ways to strengthen the 901 to some extent but don't know squat about it at this point.
    Johan
  5. #15
    Mar 2011
    Ontario, Canada
    Quote Originally Posted by VintageExcellen View Post
    Now we are talking.
    Recall which P&C's you used?
    Recall what head work was done?
    TIA
    Johan
  6. #16
    Feb 2003
    Los Angeles
    Quote Originally Posted by Uwon View Post
    Johan
    The 901 transmission can be reinforced with an aluminum intermediate plate and a billet side cover. This should help.
    Good luck.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
  7. #17
    Man, that sounds like a nice engine. Street or race?
  8. #18
    A lot of people use 2.2S pistons with 2.4 crankshafts for higher hp. The C R. is just right for sporty driving and can be adjusted with base shims.
  9. #19
    Feb 2003
    Los Angeles
    Photos
    Here is my 901 rebuild.
    Bert Jayasekera
    R Gruppe #167
  10. #20
    Mar 2011
    Ontario, Canada
    ^^^^^^^^^ That transmission is simply gorgeous. What paint did you use for the casing?
    Are the side cover and intermediate plate from California Motorsports?
    Johan
