The old fuse blocks are susceptible to losing tension, corrosion and hot spots due to high resistance. The CR uses blade fuses and includes headlight relays taking switched load off the driver dip switch. Note the relay output circuits are to be joined for both low beam lights and high beam lights. I think they are individual standard .. i.e. 4x circuits.
