Results 1 to 8 of 8
Thread: Mystery connector behind oil/gas gauge 72T
    The Netherlands
    Hello,
    Just replaced the blinker relais in my 72 hotrod and found a loose bakelite connector. No idea where is should connect to, any idea folks? Wiper interval relais 69?
    Regards,
    Cees
    Aug 2011
    Eugene, OR
    I don't recall seeing that when I reassembled my '72T. What color wires?
    - Arne
    The Netherlands
    Hi Arne,
    No idea, the wires are inside a protection sleeve. I wonder if I have a 69 wire loom in the car, or parts of it..
    Cees
    Sep 2009
    UK
    Sunroof switch maybe.?
    Senior Member 911_2.2T's Avatar
    Jan 2007
    Netherlands
    That could well be the case.....
    2.4T 1972 Targa - Tangerine German Delivery Ölklappe
    2.4T 1973 Coupe - Golden Green 911ST with 2.8 MFI TwinPlug
    1.7 1970 914-4 - Hell Elfenbein Weiss to be Sonauto GT with a Six
    Looking for engine #6522576
    Rgruppe #674
    The Netherlands
    Maybe, but the sunroof does work already without the connector attached...or I must have pulled it off...will report back.
    Cees
    The Netherlands
    Duh, I must have pulled out the connector while taking out the blinker relais. Confirmed it is connected to the sunroof switch.
    Cees
