Results 1 to 7 of 7
Thread: FS: Shifters, Rear View Mirror, Thermostat
    FS: Shifters, Rear View Mirror, Thermostat, and a bunch of parts!
    i have a few parts for sale and I'm adding to the original post. Sold the shift levers, now $250 takes all! Buyer pays shipping.
    $250 takes all!
    I sold my car and have some odds and ends including:
    2 shift levers, different years, I believe the shorter one is a 1972, has some wear on the base. other shift lever is in excellent condition and has a longer base, not sure of year. SOLD
    Shift Lever Mechanism: In pieces but believe all pieces are there but buyer needs to confirm. Will sell the mechanism alone or with shifters. SOLD
    Rear view mirror: I'm told this is 1979- but not entirely sure:
    Engine Thermostat, 1972: functions:
    Also have the flat rear parcel shelf vertical piece in leather that goes against the rear seats, this does not have the horizontal piece that is directly under the rear window. believe this piece is from a 1971 Targa. This could be used now for a driver car or recovered. Cardboard base is straight and in very good condition.
    Early 911 Dipstick, not 72.
    Parts from 1972
    Wheel bearings
    Wheel bearing seals
    2 mfi fuel injectors, untested
    oil sump plate with drain plug
    oil sump pump screen
    shifter rubber bellow
    Assortment of braided hoses in different sizes
    Clamps for assorted braided hoses
    Battery strap
    exhaust gaskets
    CV/axel seals and bolts
    A variety of other seals
    A variety of sealing washers copper
    Oil cooler seals
    flywheel seal
    MFI engine seal
    Oil Temp sender
    Clutch alignment tool
    Flywheel bolt socket- 2 different versions
    Side jack plate
    Timing light gun
    Motive pressure bleeder
    oil filter wrench
    Whatever else is in my box of parts, You get them!
    Thanks.
    Hi
    I would like to get the shift lever mechanism.
    Can you ship it to Japan?
    Thank you.
    Takahiro
    Takahiro, I sent you a private message.
    Oct 2010
    Southern Ca.
    The rear view mirror is for '79 or later .
    Richy, thanks. I updated the listing.
    Also, all parts are still for sale.
    Added a bunch of items to this. $500 takes all!
    Sold the shifter parts, now $250 takes all! Buyer pays shipping.
Tags for this Thread
