Thread: Glove box door alum. trim
    Jan 2006
    Naperville, IL
    I have three used aluminum glove box door trim/fascias for sale. Shown in the photos below there are nicks and dings present, please let me know if there are any other questions.
    1. $5, No basket weave, trim is curved/bent.
    2. $15, has basket weave and an emblem attached, basket weave will need to be re-glued. I do see a slight curve in the trim.
    3. $10, has basket weave and no emblem but does have the holes present, basket weave will need to be re-glued.
    Thank you,
    Andrew
    -Andrew
    '72 911E
    '82 931, '92 968, '93 968
    S Reg #1074
    Oct 2009
    Indiana
    all three are the same piece (same position on the dash?)?
    (i know it says "glove box door". just want to be sure.)
    Jan 2006
    Naperville, IL
    You are correct, they are three of the same, about 12.25" long with two holes each where the emblems mount.
    -Andrew
    '72 911E
    S Reg #1074
