Results 1 to 10 of 20
Thread: Anti-ethanol fuel additive for CARBS?
    Sep 2012
    Philadelphia, PA
    Question Anti-ethanol fuel additive for CARBS?
    My 72 T has a 77 911S engine running 40IDAs. Here in PA, we have winter gas with more ethanol than the rest of the year.
    I was wondering if there is a good fuel additive to counteract the effects of ethanol and keep the carbs clean?
    I’ve seen threads talking about additives for MFI cars.
    Thanks...Serge
    Serge
    Early S Registry #2457
    Aug 2005
    Bucks Co., PA, USA
    Serge, have you tried STA-BIL 360? (edit: I've been using STA-BIL 360 in my own Zenith-carbed car in the same environment as you.) Have also heard good things about K100 when it comes to preventing phase separation.
    ESR #1474
    Quote Originally Posted by teenchy View Post
    Serge, have you tried STA-BIL 360? Have also heard good things about K100 when it comes to preventing phase separation.
    + 1 for STA-BIL 360
    Apr 2011
    Central Florida
    The blue marine STA-BIL is what I use in my small engines.
    dho
    dho
    Central Florida
    Member # 1968
    Nov 2003
    Santa Monica CA
    maybe look into Sea Foam been around since 1942. It says it will clean carb jets, stabilize fuels, and controls moisture in fuels
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Hello Serge,
    Another option, beyond fuel additives, would be to seek out "Non-ethanol" or "Ethanol Free" Premium fuel in your area.
    I run it in my daily driver, all my yard / lawn equip, boat and collector cars.
    A bit more expensive up front but considerably cheaper than rebuilding a set of Weber 40's and or fuel lines, in the long run ..............
    It is available if you seek it out.
    Or perhaps you have access to 100LL avgas ? ............... which is also "Ethanol Free" ........................
    Cheers ....................
    May 2019
    Sunny Scottsdale, Arizona
    This is the one you want. Add at every fill-up.
    STA-BIL 360 Protection - Ethanol Treatment
    https://amzn.to/3mYHtCL
    Oct 2014
    PA/SC
    Quote Originally Posted by WP935 View Post
    Hello Serge,
    Serge,
    Non Ethanol is the way to go. Put in all your power equipment as well. There is a app Pure Gas for your phone(can search on you computer as well) to find non ethanol when you are traveling or at home. For me when at home, I have a local station that carries 90 non ethanol for 3.99 a gallon. I also go to my local airport and get 100LL(low lead and they will only put in cans) Its 5 bucks a gallon and I add the 100LL to the 90 Octane when I need to get above 90 octane. I live in PA as well and pay the higher prices for gas like you due to our gas tax.
    Sep 2012
    Colorado
    My engine builder objects strongly to my adding anything to the premium unleaded pump gas I put in my '69, which in Colorado is 91 octane, E10. About six months ago or so I saw a review of about ten different fuel additives done by some chemist who concluded none of them really do much of anything useful.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
    A bit of a sweeping generalization about fuel additives and their usefulness. The answer depends on many factors. They include things like local fuel quality and general engine design, for example. Various OEMs source and sell branded fuel additives for good reason. Just sayin’.
    Peter Kane
    '72 911S Targa
