Results 1 to 10 of 17
Thread: 1966-1967 door handles, Innies or Outies
    The lock cylinders on door handles changed somewhere between 1966 and 1967. The early ones are concave (innie) later ones are convex (outie) -- see photos. This is recorded as a 1967 MY change, but have no idea if it really is. I believe that I am the source, which makes it worse. If this has been previously researched, please enlighten me. I am interested in 1966 cars with original door handles with outies -- or 1967 cars with original door handles with innies. Door locks should use the same key as the ignition as far as I know.
    Anyway here are the two variations. White car innie, red car outie.
    May 2011
    Chelsea, Québec
    This is from the passenger side of 304598, Kardex date 26 May 1966 [I know they're 'innies' but the date might help]:
    Name:  handle (1 of 1).jpg
    And this from the driver's side:
    Name:  handle2 (1 of 1).jpg
    Member #1616
    Thanks, so after May 1966 -- good -- close to end of 1966 model year date. Everything helps. I'm still not wrong -- yet...
    Dec 2008
    Black Mountain, NC
    67 ROW 912 SWT from 4-27-67 (550 279) is convex, as another data point, still correct!
    Best Regards
    67 306344 is an outie ( convex )
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    305528 outie
    454310 innie
    461663 still innie
    305528 outie
    454310 innie
    461663 still innie
    Is 461663 still the original lock number from the kardex?
    Richard
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    My late 66 has one of each......sold as a 67 E, title , so, who knows!
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
    Since the door locks match the ignition, you should be able to figure out which -- if either -- is original -- unless, of course, the ignition switch has been replaced.
    Mar 2006
    8903one
    Quote Originally Posted by Brett Johnson View Post
    Thanks, I’ll give that a try. Need to locate the key first.
    Found the key! Works on the concave lock on the passenger side!! Perhaps the driver side ( convex ) possibly replaced. Only piece missing is the ignition, which I. still need to locate!!
