Thread: Winter Tire pressure
    What is a good tire pressure in my 71-911T for winter storage 3-4 month long period.I don't want them to flat spot.I put in 40lbs. a few months back and rechecked them.they lost around 10-15lbs.Any suggestions?
    Winter? What is this winter thing you speak of?
    Name:  Show weather in my current location.jpg
    So, you're LiveFromAustin and not NY?
    I’ve always felt that keeping the car off it’s tires for long term storage is better, are tire cradles or jack stands not an option you’d consider??
    1969 911 E #824
    If your car has street/road tires, and you park on something other than concrete (carpet squares are great), and you keep forty in them, they'll probably be fine for the season...
    The softer and more aggressive the tire the more and quicker they'll turn 'square'...
    I've found that on my TOYO RA1 track/street tires after one week, even on carpet squares, I'll need to drive the car for 10 min. to get'm 'round' again....
    Hope this helps....
    cm
    If you go for a top quality tyre like a Pirelli or a Michelin
    https://www.longstonetyres.co.uk/cla...rsche/911.html
    Then you shouldn't have a problem
