Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 101
Thread: Porsche Side Decal Sticker
  1. #51
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by al agustin View Post
    Michael, I think the space below Porsche is definitely wider...but the vertical 'bits' on the font does not look as wide as 15mm Hugh! This is getting all too confusing. At least this thread has determined one thing for sure, there were 2 correct versions of the Porsche script and not just Bob's.
    Hugh, please, if you have the time, could you please confirm which vertical font 'bits' are 15mm. Thanks a lot!
    Michael, do I assume all the fonts are 10mm both horizontal and vertical on your version? Thanks a lot!
    Hugh/Al
    No, the vertical and horizontal components are different on mine, more like Hughs. Most of the horizontal components on my trace come in right at 11mm. Having said that, the 'S' and 'E' on my tracing is just under 11mm and I believe I know why. They cannot follow that convention because of the negative space between the horizontal components. That small negative space is 4mm on the 'P', 'R', 'S', and 'E'. All of my measurements on that 4mm spacing are consistent. On the 'S' and 'E' if I deduct the 4mm spacing from the total height and then divide by the 3 horizontal components there is a fractional difference, not whole mm.
    If I were the guy sitting at a drawing board in the 60s, and laying it out, that's how I would have designed it..
    For some reason on my trace, the vertical components of all the letters have a greater degree of variation in measurements but, again we are talking about a material that would have been prone to stretching at the time of installation and shrinking due to age. If I were to try and guess a dimension and assume shrinkage over time, I'd probably be stating 16mm for the vertical components even though I can't reason going up to 12mm for the horizontal.
    Just looking at all of my measurements and coming up with a meaningful average, I'd say 15mm for the vertical.
    If the overall widths of the letters remain constant and the vertical components remain constant then there would be a continuity in the design of the overall 'PORSCHE'. Again, I am thinking from a font perspective and not this stripe as a standalone design activity.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  2. #52
    Interesting that the database access posted by John Gausden today includes side script PDF’s
    It’s clear that the horizontal space between the letters and Lines is smaller at top than below.
    Check it out.
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
  3. #53
    Senior Member TurkisTii's Avatar
    Feb 2012
    Chicago, IL
    Quote Originally Posted by 71gold View Post
    Didn't realize John's site is the New Zealand site...
    http://early911nzdownloads.yolasite....che-decals.php
    Agree the spacing looks like Bob's asymmetrical version. I wonder the source of the file?
    Early 911S Registry #3811
    '70 911S Coupe Tangerine
    Instagram @turkis.tii
  4. #54
    May 2019
    Palos Verdes, CA
    Is there any consensus as to which is the best you can buy on the market as of 2021? Thanks
    EarlyS Member #3823
    Typ 901 #0562
    356 Registry #53935
    1956 356A 1600N #57976 - "The Battlewagen"
    1968 911 S #11801199 - Canary Islands Sports Purpose
    1970 911 S #9110300783 - Pastel Blue Survivor
    1994 964 Speedster - 1 of 2 Amazon Blue
    Previous:
    1951 356 Pre-A Split Window Coupe #11260 - Maroon
    1966 911 2.0 Cup Car #305515
    1968 911 T/R #11820721 - ex-Linge/Bauer & Strähle KG
    1970 911 T #9110122684 Tangerine Hot Rod
    1972 911 T #9112102781 Aubergine/Tan
  5. #55
    Quote Originally Posted by maxminshull View Post
    Yes, Bob's.....
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    SOLD - 1967 911N / 1968 911L / 1967 911N / 1969 912 / 1991 964 C2 / 2013 991.1 / 2008 987 Cayman
  6. #56
    Put some on an Outlaw, 3rd party supplier, difficult to put on the big fenders. May not be installed correctly, don’t care, the facing and backing buckled and left wrinkles. Hard to see defects and no one has said anything. They broke up the big bright sides nicely.
  7. #57
    Sep 2012
    Philadelphia, PA
    More of Bob's stripes:
    Serge
    Early S Registry #2457
  8. #58
    Junior Member mikewerx's Avatar
    Jan 2020
    Fort Collins, CO
    I'm not yet convinced on the asymmetrical stripe spacing. While the overall stripe might have moved up or down on the door or was made larger or smaller overall depending whether used on the 911/911R, 908 or 917 for what looked best visually, I'm just not all in on a 4mm difference there.
    Hey Mike, Just checking in on this older thread if you were ever able to nail the script, and a way for me to utilize on my build. Glad to feed the giant and contribute if requested, just want it correct. Thanks a ton!
  9. #59
    Jul 2003
    Santa Cruz, CA
    No,,, Al and I traded emails for awhile and I started drawing my version up in CAD but, didn't finish,,, There's actually a couple of pairs for sale on EBay right now that are supposed to be W. German sourced from the early '90s and they look like they have the offset too. I was thinking of buying one of the sets to measure separately. Would be a good comparison to the tracing off the doors I had.
    20 years later, I don't think I'd trust the they could actually be used. They are 3M judging from the pictures. I have no idea of the originals manufacturer.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  10. #60
    Jan 2020
    Fort Collins, CO
    Dang... can't find it on the bay. Do you think it's the correct spacing or not the same as early 70's?
